What flows more air? 2.5 mandrel bent or 2.75 not mandrel bent
mandrel doesn't do much other than a couple horsies at most in a high-horsie application situation.
2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
the mandrel bends will just make the exhaust flow better, the larger diameter will flow more, so if you have a large pipe and no mandrel bends you will flow more but the gas in the pipe will be more chaotic, thus causing more backpressure, the smaller pipe will flow less gas, but will flow it in more of a streamlined flow. with the mods you have listed i do not think that the mandrel bends will make much of a difference, however i think mandrel bent exhaust sounds better, so your call
<blockquote>quote:</font><hr>Originally posted by BigED: Are they equivalent? I think the v8s are 2.75 not mandrel. So if I got a 2.5 mandrel, would that be about equivalent?
I'm trying to find a happy medium between our stock 2.25 and the wide open 3.0 mandrel bent catbacks.<hr></blockquote>
im wondering the same thing. 3" seems too wide open to me. i was wondering also if s.75 nonmandrel would be the same as 2.5 mandrel. and if getting a 2.5 nonmandrel would be any improvement over our 2.25
According to Magnaflow, not mandrel bending causes a 20% loss in flow. So a non-mandrel bent 3 inch pipe flows like a 2.4 inch mandrel bent pipe. To get the flow of a 2.5 inch mandrel bent pipe, you would have to have about a 3.2 inch non mandrel bent pipe.
1997 Dodge Viper GTS
Ok, I worked out the math, assuming a 20% loss without mandrel bending:
(A = r^2 * pi)
(Multiply by .8 to lose 20%)
(For diameter of 2.25, r = 1.125)
2.25 Non mandrel
1.125 * 1.125 * .8 = 1.0125
2.25 Mandrel
1.125 * 1.125 = 1.265
2.5 Non mandrel
1.25 * 1.25 * .8 = 1.25
2.5 Mandrel
1.25 * 1.25 = 1.5625
2.75 Non mandrel
1.375 * 1.375 * .8 = 1.513
2.75 Mandrel
1.375 * 1.375 = 1.891
3.0 Non mandrel
1.5 * 1.5 * .8 = 1.8
3.0 Mandrel
1.5 * 1.5 = 2.25
According to this (assuming that the 20% is correct, mandrel bending is like having a pipe that is .25 inches thicker.
ie:
2.5 non mandrel = 2.25 mandrel
2.75 non mandrel = 2.5 mandrel
3.0 non mandrel = 2.75 mandrel
You guys can check my math if you want, but it should be right.
This being correct, I guess that I should either get a 2.75 non mandrel or a 2.5 mandrel - they should be the same. I'm think 2.75 mandrel might lose me too much low end torque. Anyone agree with this?
2002 Navy Blue Metallic 3.8 Camaro M5 - Y87, Sport Appearance, T-Tops<br />SLP CAI, K&N, Whisper Lid, Pro 5.0<br />Dynomax Super Turbo, 2.75 I-Pipe, Fasttoys Quad Tips<br />Kenwood KDC-MP919, Kicker IX405D, Focal Polykevlar 165K2s, JL Audio 10w3-2 Stealthbox
just something to think about, does magnaflow make non mandrel bent pipes? so if they dont wouldnt they want to make their pipes look better by maybe saying that they flow better........ i have nothing to back this up with but a little thing to maybe think about
You, uh, never multiplied by pi. Might change results a little.
<a href=\"http://www.cardomain.com/id/byoonull\" target=\"_blank\">My Old Car - 2000 Silver V6 Bird</a><br /><br />The replacement-<br />94 Firebird Formula - 383, TH400, and a big blower<br /> <a href=\"http://community.webshots.com/user/fastblackcar94\" target=\"_blank\">http://community.webshots.com/user/fastblackcar94</a>
I could ask my astrodynamics, propulsion and structures professor next week. He's an expert in computational fluid dynamics and could probably run the equations in his head.
