would a 3 inch y pipe be ok on a na engine or would it kill the low end torque?
CIA headers?
Where the y-pipe meets the cat is already 3". Our stock cats, as I have heard, are 3" in and 2.25" out.www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
a 3" y-pipe won't kill all of the torque, but you will notice a hit in the low rpm's.. high rpm's on the other hand will benefit greatly.
Check out my ad in the for sale section for pics of the CIA headers with y-pipe ;)
2000 Magnetic Red II Automatic Coupe
Best(s): Coming soon
99 Bright Red Turbo Firebird A4 T-Tops
Best(s): N20 - 14.01 @ 97.32 (1.64) Turbo - Coming soon
what i have heard is the headers are larger than the cia's. the y-pipe is the same i think
[ December 04, 2002: Message edited by: TheBlackSwordsMan ]</p>1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
No way!, I have seen the y-pipe for the RK Sport headers and it is like 2" or something rediculous like that. It is really small compared to the y-pipe of the CIA headers, not to mention the CIA y-pipe is mandrel bent which is really nice!! CIA is the way to go if you have the money. If you don't, save your money for it, trust me.<b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
2.5 in. y pipe on the rk sports and it's mandrel bent.96 wht. firebird 5sd. rk sport headers,3in.catco, spintech catback,CAI,FRA,3.42/lsd 180*t-stat, centerforce dual friction clutch, ls1 driveshaft, polyurethane trans. mount.<br />01 blk. z28 m6, borla exht, lid, k<br />+n, sfc., chrome 18in. y2k c5 wheels.
well i had debated going ahead and getting a custom y pipe made for the time and maybe being the guinie pig for the pace setters. but im not sure i dont want to loose any low end power cause of that 3 inch y pipeno fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
A non forced induction V6 doesnt need 3" piping it doesnt flow enough air, kills the exhaust velocity.1997 Red GTP Coupe<br />Borla,3\" DP,!ubend,Thrasher CAI,Magnuson(3.4\"),1.9 roller rockers,Tran. Cooler,GPS PCM,Boost+Trans. Temp gauges(in Lotek),comp harness,Blazertech 3200\'s,BBS 18\'s+Pilots,RAT rear sway bar,Powerslots+Pf Pads(all corners),KYB\'s,STB\'s,Poly bushings(mid+end),Optima Battery(yellow), Kenwood Deck+Boston Interior Speakers(Pro)+RF Sub(550 watts), GTS covers,rear red reflective Pontiac sticker(My fav.)
does anyone know the diameter of the stock y pipe for sure
and has anyone tried running a custom y pipe without hearders?no fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
