Fitting the filters on the bottom under the splash guard i would say was the hardest part. Everything else is a breeze just remove all stock Air intake pieces and put in the new one...and walla your done.
SLP CAI
Is the no cutting on a 02 model as well? I notice you both had 96 listed
Jam,
If your talking about the SLP-21033(for the 99- 02) Then yes, there is some cutting of plastic. I installed mine in about 45 minutes. Here is a link to SLP's instructions for the kit. You need adobe to open the pdf file. http://www.slponline.com/inst/21033.pdf
Have fun,
HH2002 Camaro M5 Black<br />Propane MFS<br />Ravin RA554259 w/3\" SS Tips<br />Powerdyne Supercharger <br />SLP Cold Air Package<br />B&M Sport Shifter (Ripper)<p>She burns sweet & clean, I\'ll tell you what!
The install took me and my cousin about an hour to do...figure in 20 minutes because we let a screwdriver fall in and it was sitting in the pass. side splash guard and had to get it out. [img]smile.gif[/img]
The install was pretty easy...easier if you have an extra person, especially to pull the radiator forward. As stated, fitting the filters from underneath is a pain.
I felt a SOTP gain after a few days when I first took it on the freeway, but that feeling has gone away since I got used to it. I honestly couldn't tell you any real HP or 1/4 gains though...
is there going to be a difference between having a slp cai on 3" mandrel bent cat-back than there would be on stock pipes? i've just heard that having a better flowing exhaust sys really helps the cai work better and get more hp out...true?2000 NBM M6 Camaro Z28<br />323/335
ok i have a question about the slp cai... can i hook it up if i already have the intake lid? or is it a full replacement on the stock intake? because i obviously wont but iy if it will make my lid obsolete.later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
"ok i have a question about the slp cai... can i hook it up if i already have the intake lid? or is it a full replacement on the stock intake? because i obviously wont but iy if it will make my lid obsolete "
If you use the SLP-21033 CAI (for the 99-02),either the stock lid or a whisper type intake lid can be used. The lid I used is the Tbyrne and I didn't have any alignment or install issues using the SLP CAI.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...14 hours ago
