now i know that all of the emissions tests are different between the states, but my car is throwing the egr valve code, and i know this involves the exhaust so i was wondering if this would prevent me from passing an average emissions test with an egr valve that isnt functioning properly?
Emissions Test
The malfunctioning EGR could cause you to fail, but what's even more likely to fail you is the SES light.Matt
1998 Mystic Teal Camaro M5
do you think that if i used seafoam on my valve it would be a temporary fix to pass emissions? i have tried it before and i didnt get an ses light for like a week and then it started up again, would i be able to seafoam it and then take it to emissions and pass before it starts acting up again?1995 3.4l dark green camaro<br />stock...for now
How would you use sea foam on your egr valve? If the valve is bad its bad and need to be replaced.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...10 hours ago
