Remove Exhaust Manifold Heat Shield - FirebirdV6.com/CamaroV6.com Message Board
  • Remove Exhaust Manifold Heat Shield
    How do I remove the driver side lower exhaust manifold heat shield. I unbolted the shields and removed the upper shield, but I cannot remove the lower shield. No matter how I twist or turn the lower shield, it will not slide between the manifold and steering shaft.
    Suggestions?
    <b>1996 Camaro 3.8 L, A4</b><br />bone stock
    Mine stayed on until the manifold came off. I couldn't get it off either.
      we brought mine out through the top... dont forget to take the plugs and wires out...
      merlin
      2002 Firebird<br />2003 Yamaha YZF 600R
        No luck removing from the top ... can't fit the heat shield between the exhaust manifold and the steering shaft.
        Any other ideas?
          Just out of curiousity, why do you need to remove it?
          <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
