whats the difference between the 99 and 98 intake?? - FirebirdV6.com/CamaroV6.com Message Board
  • whats the difference between the 99 and 98 intake??
    I always see people saying whisper lids wolnt fit a 98, and stuff, and i always see engine stuff from like 99-02... why is this?
    isnt the 3.8 a 3.8?
    Also, i heard taking the MAF screen out of a 98 is bad, but it doesnt matter with the other years??
    Also, what kind of drive shaft does my car have, a 1pc, or 2 pc?
    isnt the 3.8 a 3.8?
    On 99+, the throttle body points straight ahead. Before 99 (95-98), the TB points down to the side.
    It could be either. Get down on your knees and look.
    Matt
    1998 Mystic Teal Camaro M5
      so, is it possible to just put a 99 TB on my car, and be able to use the whisper lid, and all of the other crap?
        No, not possible.
        Just get a 98 whisper lid.
        Matt
          Well, it's possible, if you get a new intake manifold and completely re-do your cruise control, but it's not worth it.
          I have a '98 Camaro and removed the MAF screen during the fall.. no problems yet.
            You'd have to way to control the throttle, because the 99+ TB isn't going to just accept the cable from the 98 car.
            With enough money and some serious fab work sure it could be done, but for all intense and purposes, it's not really possible.
            Matt
              so, is there a problem removing the MAF screen?
              I heard it causes rough idle... which im really not concearned with.
                be VERY CAREFUL while taking out/replacing the MAF screen. it is very fragile. don't even raise your voice around it. you will see...yes..you will see.
                if your car runs crappy with out the maf screen then put it back in. There is no concrete answer...yes or no to the maf screen mod. testing is the only way. keep track of your MPG and stuff as well.
                the maf screen is intedend to help the maf sensor get good and accurate readings.
                01 Firebird A4 3.42
                Powerdyne @ 6 PSI
                and other mods
                  cool, thanks.
                  Also, my friend says that you can put a blower from a grand prix, but you just need to like move something (i think he said like a hose or something... i dont really remember)
                  Anyways, is this true? From what i found, it wolnt work, because it hits the firewall..
                    hehehehehe just move a hose or something [img]graemlins/rofl.gif[/img]
                    yeah, it would require modifying the firewall to make it even fit not to mention probably a lot of other thing not well known since people dont do it
                    2000 3.8 A4 Pewter Camaro
                      I removed my maf screen, noticed no diffrence, i ended up just putting it back in because my gas milage went down ever so slightly, may have just been my imagination. As for the newer throttle body, be happy you have the one you have, i had a 99 and had lots of trubble with the newer drive by wire throttle body. I have a throttle body from a 2002 camaro, 98% complete, only missing maf senser, but you can use the one you already have. ill sell to you if you want it.
                        i removed my MAF screen....it idols a little bit rough but nothing serious...just bounches from 850 RPM to about 900 RPM's here and there...nothing to really worry about...
                        Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
                          lol, yea nothing really, my 69 camaro idles about 200 RPM differences. ;)
