I searched on EGR and the P0420 Code.
My car ever since the P0420 Code was first thrown about two months after carmax installed the cheap 3" cat on my car, has had a WOT knock or pinging sound erratically, especially when it is cold.
The SES light will come on for about 3 weeks, then after that, will stay off for about a month. This has been the cycle since about April of this year. Well I know I have an exhaust leak at the cat because the idiots decided to put a 3" cat on the stock piping, and I've had it welded shut and it still springs small leaks, so I've said screw it for the past few months.
The car just hit 100k, and nothing to my knowledge has been replaced on the car as far as sensors or accessories go. After researching, found out it could be a number of things causing this.
However, I read some EGR thread and a fubar'd EGR could cause detnonation (probably where the WOT knocking sound is coming from).
Since the O2 sensors are expensive, as well as the EGR crap, I don't want to go replacing all of that and it fixes nothing.
1)If I have to replace the EGR, how many pieces are there? Just one?
2)Can the EGR be cleaned?
Any other input on the problem? Fuel filter has been replaced, religious oil changes, have the AC Delco Iridium plugs that were swapped in at 85k (NGK TR55ix's basically), spark plug wires changed at 90k (autozone cheapy brand, fixed P0300 code) and the cat was replaced at about 76k right after I bought the car...so it has around 25k on it. Seafoamed a few months ago as well.
