I'm trying to seafoam my 96. I took off the brake booster hose while the car was running. Then, I put the hose to the tip of the seafoam bottle and my car dies. It barely sucked up any of the juice. I've tried three times throughout the day and each time my car dies, which I know it is supposed to do but the slightest bit of seafoam makes the car die. So now what?
Trying to seafoam
No, you're not giving it enough Seafoam. You need to give the seafoam faster. Then, instead of chocking out, the engine will start to idle very fast while taking in the seafoam.
The vacuum isn't powerful enough to suck it right out of the bottle, so you need to tip it till its actually pouring into the line.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
