Of all you guys who've ported and polished their maf sensors and throttle bodies, have you guys gotten any hp/tq gains or better throttle response from doing it?
Who has P&P their stock throttle body and maf sensor???
2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headersTags: None
How are you going to polish those little wires? That's what your MAF sensor is, just two wires. I was curious about this also because I saw pictures of Magnus's MAF sensor housing but finnally realized that he has an older car and his is totally different. I was looking at modifing this to keep it from hindering the air flow so much, either by shortening the down tube on there or by adding material to the back of the down tube to make the air less turbulant and flow faster around the big black plastic rectangle.
If you mod this though, you run a risk of your car not running correctly because it can't get the proper reading because it was designed that way.
If you do figure a way to modify and it working, I would be very interested.
As for the polish, I might try that this summer since I found that my roommate has a dremel that he doesn't know he has.1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
JC don't even try to port or polish the maf sensor!!!!! That's a 50 plus dollar mistake!!
And as for PNP the TB, I wouldn't unless you have a maft or maft+ and some scanning software like autotap.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
http://seppo.hopto.org/
I have done the deed ... and like Seppo say's it's a royal pain unless you have autotap or something similar.
I removed the bar between the maf "housing" and the TB and polished everything up good, including the maf "venturi". Please remove your maf sensor before doing this, and expect to spend about 2-3 hours to get it right. Now the kicker, when I first attempted this, I thought I'd just cut of the maf metering plate (behind the maf venturi assy) at the same level as the maf venturi and it would be OK ... NOT. The car ran like sh*t ...
I had to remove the metering plate totally. Now the car runs well, except ... if you take out the maf screen, the turbulence over the sensor is much worse than before p-n-p. I had to leave it in.
Autotap says I have increased the mass flow at idle thru WOT. In closed loop I run well at stoichiometric, but at WOT I run rich (about 11.8:1), so yes I still need a maft+.
Have fun ... :Dassociate of <b><i>VENOM VI</i></b><br /><br />2000 WS6 Pewter TransAm M6<br /><b>NOT</b> stock<br /><b>330/346 rwhp/rwtq </b><br />(pre-headers)<br /><br />1998 3.8L V6 Camaro M5 (the Silver Bullet) w/lot\'s of bolt-on\'s<br />-Ryan\'s car now-<br />60\': <b><i>2.165</i></b><br />1/8 run: <b><i>9.494 @ 72.57 mph<br />209rwhp/253rwtq</i></b>
so if it was programmed right, would you have seen any gains out of it? if so, how much hp/tq?2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
Don't know ... haven't finished tuning and haven't dyno'd it yet. But I can definitely feel the difference in the throttle response !
When I get it dyno'd, I will post the results.
~Steve
[ May 20, 2002: Message edited by: MidLifeSpeed ]</p>associate of <b><i>VENOM VI</i></b><br /><br />2000 WS6 Pewter TransAm M6<br /><b>NOT</b> stock<br /><b>330/346 rwhp/rwtq </b><br />(pre-headers)<br /><br />1998 3.8L V6 Camaro M5 (the Silver Bullet) w/lot\'s of bolt-on\'s<br />-Ryan\'s car now-<br />60\': <b><i>2.165</i></b><br />1/8 run: <b><i>9.494 @ 72.57 mph<br />209rwhp/253rwtq</i></b>
