FRA w/o enlarging existing slot - FirebirdV6.com/CamaroV6.com Message Board
  • FRA w/o enlarging existing slot
    I just did the Free Ram Air mod. Went real well and was super easy using a Dremel tool. The only part that I didn't do because it really looks unnecessary is the enlargement of the slotted opening (approx. 3/4" wide x 20" long) behind the radiator.
    Does anyone have a compelling reason why that slot should be enlarged. I guess it doesn't hurt but I don't really think that it would help because It definitely appears that the enlarged openings in the front are where the cool outside air gets in.
    Wow, when I took out the air cleaner I was surprised that any air got into the bottom of the box!
    Also, I fail to see why the CAI mod would be any more effective. I mean if you look at the way the radiator tilts back, it sort of acts as a scoop in and of itself
    \'01 Camaro M5 1SA \"Lightweight\" hardtop, Bright Red, Ebony cloth, FRA, Whisper Lid, B&B cat-back, Torsen 3.73 LSD, HPPIII (93 octane setting)<p>\'00 Camaro SS M6 T-Top, all GM and most SLP opts., Bright Red, Ebony leather, 4.10s, SLP long tubes, Loudmouth, CNC Stage II H/C, etc.
    I assume that it jst allows more air to enter from underneath the airbox. The stock opening is really small..i would cut it if i were you..
    2003 Fire Red Dakota R/T 5.9<p>V-Force Exhaust<br />Custom Cold Air Intake
      01 has an opening under the lid? Thats wierd cause I know mine didn't have one at all so opening it up made a huge difference. And yeah I don't think the ram air you can buy would make a whole lot of a difference.
      1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
        Actually, I just did the FRA this weekend, but I didn't do before and after with cutting the slot. I was thinking a similar thing with the slot, but you wouldn;t be able to notice a difference until the summer (well, I am in Buffalo, so it doesn;t get hot until July maybe June) I would think more air is much more important than a few degrees. The density of air changes by 0.0072 lb/ft3 for a 50°F change (from 40 to 90).
        Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
          Yeah, there was an opening under the lid of my '01. It is a long thin 3/4"W horizontal slot in the plastic piece under the rear of the air box. It couldn't have served any purpose, though before I cut the bottom of the box out.
            4 days ago
