Ok heres my idea, and please be constructive as i am not super smart when it comes to exhaust but i think i understand enough for this idea..
CIA headers, have a pipe off them into a highflo cat then out and into a dynomax bullet muffler and then out with say some nice shiney tips, just duplicate for each side or is it harder to do because of say, ground clearance issues, im guessing its not going to be just a straight line out the back, itll have to go up and down left and right to dodge other parts correct? If i am lowering my car with eibach, will this custom setup be difficult? also, if I were to have flanges welded onto all my parts, and just have like a gasket inbetween to prevent leaks, would this be a simple way to change out mufflers, cats, and that sorta thing? i think it would be neat to have the CIAs BOLTED to the pipe that connects to the cats, which is bolted to the cats and then the cats will be bolted to the pipe that bolts to the muffler yadda yadda... hmmm that sounds like a lot of flanges... hell screw that ill just have them weld everything ...i guess you can just cut it out and weld again right? i dont want to hurt my headers tho.... will true duals sound good? with the dynomax setup? i like their mufflers, cheap. [img]smile.gif[/img]
