With SLP install kit the rumbler should bolt right onto our cars right?
The guy installing my exhaust just called me and said it isn't exactly a bolt on. Looks like it is going to be short. He is having to do some fabrication to make it fit. Although some of that may be my fault, I may have bought the wrong high-flow cat (bought cto-6007 at summit).
SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
You will have to have the front flange cut off as it was intended for the LT1 cars which had the flange. Once he cuts the flange, if your cat is the same length as the stock one, everything will fit right. If not, he should have an easy time by putting a small extension or spacer in somewhere to make up for the extra length.
I called him and told him about the flange. He said he already knew that and had already cut it off [img]smile.gif[/img]
It is too short because I didn't buy the right cat. The stock one is like 24" or so and I bought a 14" one. Maybe I should have actually measured my cat before I bought one. Oh well, he is just filling up the extra 10 inches with 3 inch pipe.
When he called me I started to panic it wasn't going to fit. Turns out he was just giving me $hit though, he had it under control and knew what had to be done!
