Would a 3.4 benefit from a bigger tb?
3.4L TB
yes ;)1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
Moving to General Tech
(This is a simple mod recomendation post)Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Maybe...
If the TB is the bottleneck in the flow path, then changing to a larger TB might help. However, the cross sectional area of the plenum and the port runners may be the real restriction.
The only way to really know is to do a series of flow bench tests - bare head, head + manifold, head + manifold + plenum, head + manifold + plenum + TB. If the last test w/ TB doesn't change the flow reading significantly, then the TB isn't a big factor and changing to a larger TB wouldn't make any difference except to your wallet.83 S-10 w/95 3.4 SFI, 4L60E
Agreed. The upper intake manifold of the 3.4L has to be one of the weak points of the engine & the reason it doesn't make power as easily as the 3.8 does. The swap to the LT1 TB & revised plenum on Tiago's setup is a step in the right direction in order to squeeze more power from the 3.4L.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
What is different about his plenum besides the LT1 throttle body? Is it ported? Any other differences? I have a LT1 TB on mine but that is all it is modified.Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
