need a little maft help please - FirebirdV6.com/CamaroV6.com Message Board
  • need a little maft help please
    when the power pack is completly installed, can i get away with a maft? and not a maft+? the maft is said to be for LS1s and i think it said the maft+ was for LT1s. any help would be appreciated.
    [ February 27, 2002: Message edited by: nino ]</p>
    6s.......under the hood or under the belt, they just dont cut it.
    anyone?
      You can use a regular MAFT to play with your air/fuel ratio.. BUT if you buy a MAFT+ you can even change your timing advance and could gain another 5+ rwhp.
      Both will work though with our MAF setup. I tested a regular MAFT on my car before I bought a MAFT+.
