SPL CAI Problems. - FirebirdV6.com/CamaroV6.com Message Board
SPL CAI Problems.
  • SPL CAI Problems.
    Ever since I installed my CAI my Service engine light has been on. I think its cause my SLP sensor hole doesnt fit my stock air sensor very well. ( possibly leaking air ) but I was wondering what most people did with their stock sensor to get it to fit into the slp. On my slp all there is is a hole for the sensor to slip in, no connection like the stock box. so I shaved it a bit and it fits decently. What did the rest of u do
    97 Special Edition Bird , Short bus stlye special
    Are you talking about the 02 sensor? I removed my whole 02sensor unit from the stock airbox then I put it into the little hole in the 1LE elbow then connected it and it was fine. Im not sure if this is what you are talking aobut.
      yeah thats what Im talkin about, It didnt fit right until I shaved it up. and yeah. [img]graemlins/fluffy.gif[/img]
        i believe you are describing the iat (intake air temp) sensor. if you are getting a check engine light, its not likely due to air leaks. during the shaving operation you probably damaged the sensor (or, hopefully not, the wiring). a new sensor is pretty cheap ($12 or so). when i put on my whisper lid i needed to lubricate the sensor with a little dish liquid (dont use an oil based lubricant) to get it into the rubber boot on the intake piping.
          You know I was curious about the same thing when I installed my SLP.. the instructions don't say anything about the sensor really I had to figure it out on my own. I took the one out of the airbox as well and had a large of problem of getting it to rech the hold on the SLP.. I fianlly got it in there though. THey shoudl put that thing on the right side not the left.
          Check out my Polo Green V6 38 SPecial at Cardomain.com <a href=\"http://members.cardomain.com/wicked_v6\" target=\"_blank\">http://members.cardomain.com/wicked_v6</a> and vote for me
            yeh, a leak will cause it to trip if its affecting temp. but the reading im getting is something like a temp offset air intake and an overactive reading either intake or maf?
              sorry but there isnt an 02 sensor in the airbox its the iat sensor, mine fit fine when i had the slp cai on.
              Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                Will the SLP cai work ona 3.4?
                \'94 Pontiac Firebird 3.4<p>MODS<br />Custom CAI, by pass cat,<p>soon to come<br />SLP CAI, sweet thunder exhaust, 1.25 lowering springs, 3 pt sub frame connectors, traction bar, port & polished heads & intake manifold, Headers, strut tower bar, ram air hood, SLP rims 18 in, tires? any suggestions? E-mail at firebird1206@aol.com
                  keith: yes SLP cai is available for 3.4L
