Ever since I installed my CAI my Service engine light has been on. I think its cause my SLP sensor hole doesnt fit my stock air sensor very well. ( possibly leaking air ) but I was wondering what most people did with their stock sensor to get it to fit into the slp. On my slp all there is is a hole for the sensor to slip in, no connection like the stock box. so I shaved it a bit and it fits decently. What did the rest of u do
SPL CAI Problems.
i believe you are describing the iat (intake air temp) sensor. if you are getting a check engine light, its not likely due to air leaks. during the shaving operation you probably damaged the sensor (or, hopefully not, the wiring). a new sensor is pretty cheap ($12 or so). when i put on my whisper lid i needed to lubricate the sensor with a little dish liquid (dont use an oil based lubricant) to get it into the rubber boot on the intake piping.
You know I was curious about the same thing when I installed my SLP.. the instructions don't say anything about the sensor really I had to figure it out on my own. I took the one out of the airbox as well and had a large of problem of getting it to rech the hold on the SLP.. I fianlly got it in there though. THey shoudl put that thing on the right side not the left.Check out my Polo Green V6 38 SPecial at Cardomain.com <a href=\"http://members.cardomain.com/wicked_v6\" target=\"_blank\">http://members.cardomain.com/wicked_v6</a> and vote for me
sorry but there isnt an 02 sensor in the airbox its the iat sensor, mine fit fine when i had the slp cai on.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
Will the SLP cai work ona 3.4?\'94 Pontiac Firebird 3.4<p>MODS<br />Custom CAI, by pass cat,<p>soon to come<br />SLP CAI, sweet thunder exhaust, 1.25 lowering springs, 3 pt sub frame connectors, traction bar, port & polished heads & intake manifold, Headers, strut tower bar, ram air hood, SLP rims 18 in, tires? any suggestions? E-mail at firebird1206@aol.com
