I just ordered a high flow cat. i work at a motorcycle shop so i was just got to put it in. can you remove just the y-pipe and not the manifolds? can anyone tell me how too or give me some help? what would be the easiest what to do it?
Removing Y-Pipe
Removing Y-Pipe
<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)Tags: None
you can just remove the y-pipe. there are two nut and bolts on each side. real simple. you'll see when you get under there
yeah, WD-40 would be good to do, but he has a 2002 and my 2000 wasnt hard at all
Would it just be easier to take the y off? i mean i wanna make sure these a good solid welds. i got a carsound 3in in/out. im going to take the rest of the pipe off and just run a turn down for now. over the next 2 or 3 weeks ill save up my money and get the loudmouth. should my cat just slide right onto the y-pipe. ive heard thats its 3 in but im not sure. thanx!<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
