Well after driving it last night when I got home the pipe came loose over the axle area. The clamp that was on it, was a U bolt clamp that came with the exhaust.
Today I and my friend re-tightened the band clamps up around the cat (they were maybe 1/4 turn loose than yesterday and we got them really tight again), and we replaced the U bolt clamp with a 3 inch band clamp around the part that had previously came apart. I really hope it stays on... I know that those 2 pieces dont really overlap as much as other areas of the exhaust and it was a little difficult lining then up, so I dont blame the U bolt clamp for not being able to hold it well enough (even tho it crimped the pipe a lil).
Anyways, now i am a bit scared of it being bolted together with those band clamps but they held up well at the front. The rear scares me a bit. I hope it doesnt keep hitting that one part that goes across the rear by the wheels. It can be unbolted, there are like 4 bolts in it (sorta like the thing that is behind the cat which i had to remove to take it all off in one piece). I hope you understand what I mean. lol its maybe like a half an inch from hitting it but if i hit a bump i believe it will hit and cause it to come loose again. I just pray not!!! lol
I will probably make another post with pics.
Anyways how low from the ground is the exhaust supposed to be? since the pipe with the resonator/muffler on it is really big around its like i dont have much ground clearance... speedbumps could be a problem.
What worries me isnt really scraping the ground, its hitting bumps that might cause the over axle pipe which connects to the rear section to come loose again.
Ummm i think i covered all of the concerns. I love the sound it makes during idle but when i even lightly touch the gas its freaking LOUD like an airplane. TOO loud. LOL
BTW I think its so loud cause of the high flow cat i put on. true or not?
Sorry i dont know the name of anything really.
