Ram Air - FirebirdV6.com/CamaroV6.com Message Board
Ram Air
  • Ram Air
    What are some good ram air kits out there and what delivers the most bang for the buck?
    Red 1998 Camaro 3.8<br />K&N and Home Depot<br />2 12\" JL W3v2 Subwoofers<br />-more audio stuff to come-
    http://mods.firebirdv6.com/intakeexhaust.html
    Mouse over the "intake" section. This should answer you question.
    Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
      Ram air doesn't exist for our cars ;) Now if you want a free flowing cold air kit we can prolly find some. However they all do the same thing so pic a brand you like a put it on your car. Check the site's sponsers they all sell "ram air" kits.
      00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
        My ram air
        http://members.cardomain.com/sorn09
        Black 2000 Y87 Camaro with T-tops ,SLP bowtie grill, Suncoast Creations Ram air hood and air box,Hypertech pp3,magnaflow cat back,and hi flow cat. <a href=\"http://members.cardomain.com/sorn09\" target=\"_blank\">http://members.cardomain.com/sorn09</a>
          there are ram-airs but not like most people think. i have the Super Sucker Ram Air(SSRA) it comes from the bottom. you can also rig up a real SS ramair to your car. people have done it.
          2000 3.8 A4 Pewter Camaro
            ive seen the one that comes from the bottom...does it work good?
              hey speedfreak thats a SS ram air setup thing isn't it?
                There is:
                SLP Cold Air Induction
                Fast Toys Ram Air
                Those are the main ones.
                Black 1997 Camaro RS<br />Mods: Headlight, Fog Lamp, Blinker, and Tail Light Blackouts<br />35% Tint Window Armor (www.windowarmorusa.com)<br />Upcoming: Replace failing driver\'s window motor and Black Power Antenna<br /> <a href=\"http://members.ca
                  the ones from the bottom work good. i got the ASSRA cause it was blastic so it wouldnt absorb heat and it was a full ram air. not like the rest thats open in the middle. its a pretty much closed box all the way up.
                    No it's the Suncoast Creations ram air.
                    Its mutch beter than the SLP kit. The Suncoast kit seals the large opening in the hood directly to the new larger airbox.(Takes the largest K&N they make) take a closer look at my pics
                      will the ssra work on a 2001, and if so what mods/ fabrication are/is required?
                      92 25th rally sport garage baby, 97 30th rally sport, 01 camaro garage baby. obsessive compulsive camaro fan. id rather push a camaro then drive a rice burner.
                        2001 and 2002 are the same as 2000 I believe there were no changes to the front end.
                        When I installed my Whisper “ram air” kit it wasn't very pull it out of the box and just bolt it on it took a lot of modification and damn that stainless steel is hard sheit! I had to elongate the holes that you use to mount it to the radiator support brace and the 3 bolts under the car that hold the plastic scrapy thing by about a quarter to half an inch each for something that was supposed to take 45 minutes installing it took about 4 hours. It's worth it when you hit your power band you will feel it accelerate harder.
                        <a href=\"http://www.cardomain.com/id/exzodious\" target=\"_blank\">2000 Pontiac Firebird</a>
                          i did some searching around and all i could find as far as SSRA was a kit for the LS1. is this like the V8 exhausts where you just need another part to install it on a V6? also, this probably wouldn't work on my '96 would it?
                          1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
                            No, it wouldn't
                            Shawn<br />2002 Silver W68 Firebird
                              No it wouldn’t work on a 96 since it doesn’t have the air box lid set up but I think any ram air kit for the LS1 would fit the 3800 perfectly since the air box lid base is pretty much the same and even then most of the ram air kits say they fit both the LS1 and 3800.
