I am in the middle if installing headers and have the driver side done but the other side I have a bolt stuck it will not come out. I have gotten the old header off but the the new header will not fit with the bolt on its has to slide on and to ad to that on the same side a bolt broke off. everything would be cool if it was for these 2 bolts. IF anyone can help me out with any ideas that would be great. I even liquid wrench the hell out of all the bolts be for I started.
[ December 14, 2002: Message edited by: Go4broke ]</p>
If I remember correctly there was a bolt on each side of the heads that were not meant to come out. And I don't recall having that hard of a time with the passanger side. I know I had to actually lift the motor to get the drivers side in.
Are you trying to come in from underneith? I believe that's how I came in and out. I only remember having to really push the A/C lines out of the way to get them on.
[ December 15, 2002: Message edited by: Seppo Kaitainen ]</p>
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre http://seppo.hopto.org/
well I finally got the bolt off. What I did was put 2 nuts on the bolt and backed out the first nut with the 2nd one in front if it. I finaly got both the header on now and it sounds so damn loud. I can't get the Y pipe to bolt up to both the headers so I just going to have a shop finish it up while the reweld the exhaust.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
