do the rpms bounce around and the car won't hold an idle, or does it jump once when you throw it into neutral and then it idles fine? if it's the first, you may wanna check for vacuum leaks.
goto a autozone and find out what the code is that is triggering the SES light and then we will go from there autozone will scan it for free
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Less restriction on the exhaust will make your revs hold high longer. IF your not getting an ses and its just going to 2krpm then back to normal I wouldnt worry about it.
