i was wondering if this could be a solution to take at least an 1" out of the hump in the floor:
cut out the cat and put straight pipe in and then cut the floorboard and straighten it out a bit (hammer or cut) and weld it back into place, cut the carpet a bit to fit, and !voila! passenger left foot room?
98 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
try it, and see how much a PITA it is. it'll cost a bit if u have somebody else do it, maybe 300-400. also, u cdon't have to take the cat off, u can get almost an inch of room between there anyways.
