2000+ manifold conversion - FirebirdV6.com/CamaroV6.com Message Board
  • 2000+ manifold conversion
    I got tubular manifolds with Y pipe of 2002 Camaro and did installation yesterday. I used vipers guide. For tubular manifolds it is little bit different.
    Difficulties:
    1. Air condition tubes of the compressor are on the way.(pass side)
    2. Oil dipstick is on the way (deriver side)
    3. EGR hole is in the different location.
    4. 3` pipe by the cat is not round (bad if not welded)
    Bending those tubes makes installation possible.
    Pros:
    1.You can do your sparkplugs in 10 min
    2.I had mine painted before install – manifolds look awesome!
    3.Way better flow, especially for the price/value ratio.
    I didn’t feel any noticeable performance gains, but my muffler definitely sounds louder/deeper. So there is, probably little gain.
    Now troubles:
    First stud that I did(pass front) I have broken.. (very good start..), the rest went very easy. How would I get broken piece out?
    Ticking noise from the driver side, I guess EGR tube is not sealed. Can I just plug that hole with the bolt and be done with it? Options?
    what did you guys mean by the tubular headers are there any sites with them if there are please reply. definatly wanna check thoes out also .
      also i forgot to add. what are some great bolt ons and free mods for the 99 w68 bird w/ the 3.8??
        GM finnaly realised that they manifolds s4ck, so starting from 2000 and up f-bodies got better tubular manifolds. they are still not greate like pacesetters or CIA, but def flow better. And yes , you cant beat the price for those.
          where can you find pacesetters cheap ??like a website?
            6 days ago
