Ok, so I want to order the magnaflow catback, but I want 3" piping, the cat back comes with 2.5" piping. No one here on Maui has a Mandrel Bender, I want Mandrel bent. Is there a place to order a system like this? If so, could you post a link with a good place to get it, to the direct part?
Where to get 3" piping
You have to get the system for the 5.7, it will fit our car though.
http://www.lmperformance.com/2381/1.html
http://store.summitracing.com/1999 Firebird
Dynomax sells them through Summit: WLK-53061 and WLK-54064. You need both of them.Matt
1998 Mystic Teal Camaro M5
If you want a whole catback that comes with the pipes, any system for a 93-95 lt1 should come with the full mandrel bent 3" piping INCLUDING the s-pipe. Go to the APPEARANCE section and look under my post of pictures of modifications, I had a pic of the s-pipe area from the catback I bought. It was a 93-95 single cat LT1 3" system, came with the s-pipe already.1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
