Opinions on my plan? - FirebirdV6.com/CamaroV6.com Message Board
  • Opinions on my plan?
    Taking a big of a plunge here, would like to know what everyone thinks. I think I have come up with a pretty good setup and questions are welcome.
    2000+ Manifolds
    Stock Y-pipe
    Catco #6007
    3" S-Pipe (inspired by shortdog, two 45 degree mandrel bent pipes)
    Stock LT1 I-pipe
    - then my dynomax muffler and tips which are already installed on an otherwise stock exhaust.
    My only mental hangups are possible SES light and how it will sound. I've heard a bit about raspiness with the high flow cat. I've decided to charge on ahead with it anyway. Labor isn't an issue, so what's everyone think?
    [ August 23, 2002: Message edited by: DrSquirts ]</p>
    www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
    Try and port the manifolds as much as you can before you put them on the car. That will help alot. Should work well.
    Scott
      Thanks, Scott. I searched it on the board here. Unless it's easier than I think, I don't think I have the facilities available to me to port the manifolds, even though I would like to. Would going as far in as I can with a dremel do the trick?
        Yeah, that would not hurt. You'd be suprised how far you can actually reach down into those manifolds since they are shorties anyway.
        Scott
