I was told that it decreases temperature like 30% and will result in more hp is this true? If say the headers and intake was coated?
I was told that if the headers and upper intake are jethot coated you will get more..
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
Hmmm, that is an interesting idea...
you would want to port & polish the intake before doing that. I dunno how thick the coating it, but you would need to mill off that or more (hey, while your at it, might as well go aggressive).
But yeah, if it really did lower intake temps, it could increase hp.2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
My intake is ported and polished from ssm, jet hot told me they can coat the outside itselfLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
The only thing it will do is reduce heat. I know the intake will like the reduced heat but im not sure if its worth that much of a gain. Headers will not notice a difference because headers like to be hot. It helps scavage the exhaust gases out faster when the exhaust is hot.
<blockquote>quote:</font><hr>Originally posted by pgriffith:
The only thing it will do is reduce heat. I know the intake will like the reduced heat but im not sure if its worth that much of a gain. Headers will not notice a difference because headers like to be hot. It helps scavage the exhaust gases out faster when the exhaust is hot.<hr></blockquote>
It doesnt actually reduce the heat on the headers but keeps the heat in and out of the engine compartment which in turn keeps the exhaust gases hotter and the engine cooler which results in more hp. Plus it looks really nice :D
Gerry<b>2001 Black Trans AM M6</b> <br />!Hood baffles,!CAGS,Mufflex Cat-bypass pipes,Borla y-pipe,TSP Rumbler cat-back,LGM lid,G2 springs,BMR SFC\'s,BMR STB,LGM billet pedals,Lou\'s short stick,Custom FRC\'s,Custom hood and side vents,Polished 18x9.5 Z06 wheels
Car Craft had a test on jet hot coatings. Turns out Dynomax has two identical headers, one painted, one jet-hot coated. To give you and idea of the difference:
Jet hot: $200 more
Painted header temperature: 520(!) degrees
jet hot temp: 198 degrees
Painted header paint life: about 10 mins. (flaked off)
jet hot life: lifetime warranty
painted header color (after flaking off): rust
jet hot color: silver, almost chrome look
Hope that gives you an idea. Personally, I think it's well worth it.16 years old with no car and big dreams...
especially since i got in on the deal before it was to late 30% off [img]smile.gif[/img]Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
what happens paintwise if u paint them w/silver hi temp paint? would that flake off too??98 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
my heads are milled .020 and my upper intake is ported and polished, will having the jethot coating affect anything on my parts? can jethot coat the intake just on the outside and if they do coat the inside will it affect the performance from me having my intake ported polished, will i need to get it reported and repolished?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
I have been just informed that jethot only externally coats the upper intake so i wont have any problems with it being ported and polished.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 hours ago
