I'm trying to install my CAI from slp and i'm at the point where I have to remove the air deflector from the ac condensor coils. I know it has 4 pins holding onto a larger piece of plastic but I can only find two of the pins. The ones by the hood latch. and I can't even figure out how to remove those!!! anybody who has done this install please help.. need it asap.
SLP CAI install PLEASE HELP!
2002 Firebird Y87 & W68, A4, Magnaflow Exhaust, Whisper lid, K&N, 3.42 gears, LSD<br /><a href=\"http://www.cardomain.com/memberpage/770634/1\" target=\"_blank\">http://www.cardomain.com/memberpage/770634/1</a>Tags: None
its the v 6 rigth ?
i dont have one off tham an my car but i think i now
why u cent remove it you now that when you open the
cover like u try to change your air filter uner it
you have i think 2 or 4 srcus that u have to tak uot
it is to cold outside to check but if you still need
help let my now i will look.
is this CAI bather then the one from K&N Generation II FIPK®
what air filter r u gone be using ?? becouse that will only give u suposliy colder air t your filter
rigth ??? so what gouse on top of this
rigth now i'm think off buing one of those but i dont now that is beather this one or the K&N
damn man I didn't understand a word you just said man, lol
Cros I was planning to install my whisper ram air kit today but it rained so can't help you out just yet, I'm sure a few others should know what to dop though.<a href=\"http://www.ltr450hq.com\" target=\"_blank\">http://www.ltr450hq.com</a> <br />2002 Pewter Camaro-------------<br />-T-Tops -K&N Air Filter -Whisper Lid -Fast Toys CAI/RAI -Billet Grille -Decals All Around.
you have to get under the car to get to the lower two plastic push pins that hold the shroud. they are on either side of radiator mounts. they make a fork like tool for removing push pins but you can use your hand and or screw driver to pry them up. push from the back while you pull from the front.
The upper two push pins 'rotate' and lock into place. turn them and pull the out.
don't forget to use a piece of cardboard in front of radiator while you are installing the kit. it is very easy to damage the radiator.
