How long does it take to install and is it hard to do? What problems did you have with it?
SLP CAI installation questions
Its really easy, if you have a dremel. It took me about an hour, given it was my first time doing it. I never ran into any problems, just follow the directions it comes with and you will be fine.
[img]graemlins/thumbsup.gif[/img]Go Fast or Dont Go
It's very easy to do. It shouldn't take you more than 30 minutes.
I had a problem with my install though. I don't know how the throttle body differs from the years, But I had a hard time getting the rubber elbow part over the SLP piping. The cones will also be a tight fit.
Good luck94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
I did mine yesterday (I have a 3.8) and had absolutely no problems. Only tools I needed were a ratchet and a flathead screwdriver. Its fits a bit tight, but its nothing a little manhandling can't fix! :D1997 Chevy Camaro<br />3.8L V6 w/ SLP CAI...check out the gallery on <a href=\"http://jaredmiller.sphosting.com\" target=\"_blank\">my website</a> to see more
It's pretty easy. I did mine in about an hour and a half, and I took my time with it. The only tools you'll need are a drill and a jigsaw. When you go to drill the holes in the car, make sure the drill bit is about half the diameter of the screws. Other than that, you should have no problems. Have fun!2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
Camaro_SLP ........
TireGuy........
Jared..........
Wrong intake [img]tongue.gif[/img]
