LOL: another phoenix out there. cool. how did you come up with 64? i picked 99 because my firebird is a '99. ne way what plugs are better with headers and new wires and some coil packs. i broke down and bought some MSD coil packs and some wires,i'll go ahead and do these when i do the headers. Are Bosch's or NGKs better for our car?
any problems with pacesetters?
i used the stock GM ones in my car. lol i should have got new ones (will do) but they should seal fine there $16 for ech side though lolwww.turbov6camaro.com
1997 3800 Series II Camaro
DO NOT DO NOT DO NOT get th FEL- POS i MEAN PROwww.turbov6camaro.com
i wrapped mine up with little kid droppings~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
For the gaskets I used the paper ones that came with the headers, and soaked them overnight before installing.
Then after you install it, warm them up, let it cool a bit and re-torque it. Do that about four to six times. It's a pain in the ***, but it's been six months and no leaks.
The install was tough, but if you have someone else it will be better (and I was working in the Phi Delt parking lot here). Totally worth it though, finished off the exhaust system.2002 Black Camaro Y87<br />Whisper lid, FastToys ram air, Hurst shifter w/ Lou\'s Short stick, Borla Cat-Back, Pacesetter Headers, 3\" Catco, 1LE Aluminium Driveshaft, Taylor 8mm wires, Bosch +4 Plugs, and MSD-DIS HO Ignition.
i just ordered some pacesetters too. But what did u soak the gaskets in over night?1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
Some members have soaked them in water.
I ordered Pacesetter Headers too! :cool:
But I am going to get New GM OEM Gasketes instead. [img]graemlins/bowdown.gif[/img]<b>2000 NBM Pontiac Firebird</b><br />3800GT Performance Package<br /><br />Intake, Magnaflow Cat, Flowmaster Cat-Back
Yea, just some water will do the trick. If you take the time and do it right it shouldn't leak. I was impatient, and didn't want to wait for new OEM gaskets, and it's worked out fine for me so far.2002 Black Camaro Y87<br />Whisper lid, FastToys ram air, Hurst shifter w/ Lou\'s Short stick, Borla Cat-Back, Pacesetter Headers, 3\" Catco, 1LE Aluminium Driveshaft, Taylor 8mm wires, Bosch +4 Plugs, and MSD-DIS HO Ignition.
im going to be runing like 20+ PSI of boost im thinking the paper ones are not going to hold up lol new OEM ones for mewww.turbov6camaro.com
