I'm buying a new converter and putting on the s-pipe I got with my cat back system which is 2 1/2"
Since it will be 3"id 3"od I'm going to just put a reducer pipe coming off the converter. With the added reducer pipe, will I have to trim off some of the s-pipe or I-pipe for it to fit?
Also, where should I weld the O2 sensor back in?
Thanks
