When I put in my headers, I reuse the o2 sims that are in the manifolds right? Then, the last one in the s pipe, do I reuse that one? I heard headers=ses code, so how do I avoid that? Use an o2 sim in the s-pipe? Which one works? Iv'e heard of some that throw codes anyway. I would rather not stare at that orange light, I hate it. My 92 Camaro was on all the time. It was a basket case.
o2 sims
my headers didnt make an SES and I have o2 sensors in the headers and an o2 sim at the s-pipe and we're both '99s so i dont see why the same combo wouldnt work for you [img]smile.gif[/img]\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
sims are simulators
sensors are sensors.
use the o2 sensors that are in your manifolds now and
put those in the headers.
Put the rear 02 sensor that is in the stock S pipe in your new S pipe. If you get an SES code from the headrs you will need to add a SIM to the rear o2 sensor wires.
the manifold sensors read and adjust the engines A/F ratio. The rear o2 sensor measures emissions.
Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
