9 outta 10 times I check under my hood, the steel clips that lock down the lid, are unlatched...only happened after I installed the Whisper lid...any hints on making it more secure?
Whisper lid - keeping it SHUT.
it's prolly not aligned right when you clip it on.
The top of the lid on mine is place more in than the lower part. like an "underbite" I guess you would call it.1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
I think I have shoved it back as far as it can go, but I will try some more.Slick - US Military - overseas. <br />\'01 Pewter Firebird \'Vert<br />SLP CAI, MSD coils/cables, Whisper lid, Pacesetter Headers, Borla 3\", Catco 3\" cat, K&N filter, Intense Racing PCM, Lakewood LCAs,180 TBI--> BMR PHR, ZT LSD, Motive 3.42s, FFF Turbo
hmm i only have one clip holding mine in and it has done fine. Anyone know where i can get another clip, i have been missing mine since i got the car.1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'s
friend has the same problem...Purple \'95 A4 RS...Totaled in \'03 23,000 on her :( Red \'95 Camaro M5...A Few Goddies!<br />84 Chevy 6.2L Diesel 4x4 10in. lift 38x15.50\'s<br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a><~Member
Tape the clips down to the box. No matter how many times i pushed it back and reclipped it and always came unclipped.1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
i had this problem a while back. I assumed it was a smooth hose i used to the throttle body being to stiff and keeping it from latching. I took thefilter out to check it and put it back on and it has held since. If adjusting the filter and lid wont work, maybe putting a slit(not all the way through) where the latches go.97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
also, make sure that the front lip of the whisper lid is sitting in the groove in the lower intake part. mine didn't fit right for a while until i found that the front lip goes in the groove. now it's a tight fit, but the clips never come undone.2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
Just as everyone else here with the whisper lid I've had the same problem. Some weather stripping (1/2" width recommended, double up if you have too. But no more than a double layer) from your local hardware store or "Wally World" applied to the lid(in the areas of the contact to filter base) should solve the problem, mine hasn't come loose yet. It creates a tighter seal, so if your running a CAI you'd get more of your money's worth out of it, plus it would also create a more resistance for the clasps on the filter box. If all else fails, check your lid alignment, as everone else has suggest and maybe add a professional look by safety wiring the clasps in the closed position(just a thought).BLAHHHH!<br /> <a href=\"http://members.cardomain.com/chris98\" target=\"_blank\">http://members.cardomain.com/chris98</a>
