I actually run the same setup minus the headers and I bought the 02 sim and it didn't work for me. It ran without the light for like a day then it came back on.
\"I\'m going to torment you beyond the end of time, and hit you with a steamroller!\"
I am plagued with the same problem however i have only replaced the cat w/ catco highflow and redone the rest of the exhaust back. It really comes down to, if you mess with the cat your going to get SES light on the 00+ year models, atleast 85% of them anyway. The sim worked on my car for about 2000 miles and has thrown consistant codes since. Even after i reset the pcm, the codes will come back in about a week.
What O2 Simm is everyone using right now? I got my from ZZPerformance.com, it doesnt look like the casper electronics one its MUCH smaller. Maybe this is the reason for me?
2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
I'd love to look at the pcm code on the post-cat O2 sensor. Something tells me there's a change that means that O2 sims aren't being smart enough (sending constant signal when the PCM knows it should be changing). If I knew what it was looking for, it would be easy to rig up a "true" sim that maybe took in the rpm and throttle position and adapted its output to suit. Or maybe read the output of the pre-cat sensors and output based on that.
-Jeff
2001 Pewter Firebird Y87, M5
I'm getting the SES from my O2 sim also. I have a casper sim. Several months ago, someone on the board contacted casper and was able to have casper send them another O2 sim that will work with the 2000+ cars. I've been meaning to do so, but I've been a little busy working 7 days a week for the past month or so. :( I need to do that Monday. [img]smile.gif[/img]
Just call casper and tell them your problem, and they should be able to help yeah out. [img]smile.gif[/img] I bought my sim from Summit Racing and it's listed under the Grand Prix, that'z the reason why it throws the code, I'm guess on the Grand Prix it sends a different voltage signal than the Camaro/Firebirds. Hope this helps. ;)
[ October 12, 2003: Message edited by: Guardiannknight ]</p>
