o2 sim? - FirebirdV6.com/CamaroV6.com Message Board
o2 sim?
  • o2 sim?
    I think i have deicided on putting a bullet muffler in place of my cat. The question i have will i have to get an 02 sim or will it be ok. it 94 3.4 w/flowmaster catback
    Yes, get one to keep the SES light from coming on and to give the sensor a valid reading.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Were do you suggest the best place to get an o2 sim?
        I am pretty sure that thunder racing sells them..
        but you can get them anywhere.. jegs, summit.. ect ect.. they are all pretty much the same.. it will cost you areound 60-70 bucks.. and you only need one! dont buy two..
        ~Billy
          clubgp.com sells them singly for $45/ea
            I thought you only need an O2 sim. if you have a 3.8 that has an oxygen sensor after the cat. The 3.4 only has 2 sensors. One in each exhaust manifold before the cat. I have a high flow cat on my 3.4 an have no problems with "the light".
            However, if you have a sensor behind the cat and it reads levels leaving the cat you have to have simulators...right?
            Not arguing, just double checking.
            Dr Todd
              I just got mine from jegs for 44.99 yesterday. ZZ performance has them on sale for $37 right now.
              Also, you only need to change the one behind the cat becuase thats the one that throws the light for emissions reasons. The other 3 control the air/fuel ratio.
              [ June 18, 2003: Message edited by: jonny985 ]</p>
              1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
                Go ahead and disregard anything the 3.8 guys are saying about sensors around the catalytic converter. Dr. Todd is right when he says 3.4's don't have any down there. Ours are in the Y-pipe just below the exhaust manifolds. Our sensors take their readings way before the cat. Therefore, you won't need any sims. I ran a straight pipe (no cat) and had no trouble codes.
                95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
                  so i got a 95 3.8 lt. and this will fit?
                  http://www.zzperformance.com/zzp/pro..._simulator.htm
                  it says for 97-2002 vehicals. i thought it went in place of the sensor too.....
                  <a href=\"http://camaroz28.cardomain.com/id/onoiocoko\" target=\"_blank\">http://camaroz28.cardomain.com/id/onoiocoko</a> <br />\"there are three kinds of people - those who can count and those who can\'t\"
                    dam.. you may not need one w/ a 95.. it depends if its obdii-2 or not.. i am not 100% sure about the 95's
                    jsut hold out a bit someone will know..
                    ~Billy
