Anybody who has put 2000+ manifolds on 99 - FirebirdV6.com/CamaroV6.com Message Board
  • Anybody who has put 2000+ manifolds on 99
    Did you need to reprogram the PCM do work with the new manifolds, or will the 99 programming learn them?
    Also, is there anything other than the air conditioning refrigerant lines from the back of the compressor that would prevent the 2000+ manifolds from going in, i.e., is the compressor mounted farther back on the 99s, etc.?
    I've the got the manifolds, I've got the y-pipe, all I'd need (that I know of) would be to change the AC lines, and I could install them. I'd like to do the swap, but if it's going to require reprogramming, etc., I'm not going to do it.
    Oh yeah, and did you notice any change in the performance of the car, more top end, etc.? I've heard yes and no. Thanks.
    [ June 17, 2003: Message edited by: Guardsman ]</p>
    No reprogramming should be necessary.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      No reprogramming...I was going to do the same thing to my 99.....right now its a waiting game to see if I can afford the headers before I go with the 2000 manifolds......
      Eric
      Eric
      2005 Mustang 4.0
      1996 Camaro Conv
      2000 Ford Excursion
      "Darkness Falls"
        I urge you to do a search for posts containing "manifolds" by member 813 before you dive into this project.
        www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
