i need a new rubber exhaust hanger does anyone know where can i order one or the part# all the shops around me dont have the right size one and they all are like different part#'s :mad:
Exhaust hanger part#
I need a new one also... but i dont want the GM kind... i want ones where the 2 holes are closer together cause the GM kind (which was on my car) is stretched out and i want it more firm and basically i want it pulled up higher. A shop i went to sorta put in a new hanger for me right where the pipe comes down from the over axle part (they added the hanger and a bolt which is holding up well) but its stretching. I want to replace it with a newer/firmer one.<a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
go to you local muffler shop whatever it may be and tell them what you want. they will have plenty and many of them wont even charge you from my experience.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
