Which one is better and what performance gains are expected? Im thinkin of removing my gutted cat and puttin in the pipe. What yall think?
Gutted Cat vs Offroad Pipe
For Sale<p>Mods so Far:<br />Tb Coolant Bypass, NGK Vpower Plugs, Accel 8mm Wires, Gutted Cat, TransAm Muffler, K&N FIPK, Crower Baja Cam, Comp Cams Magnum Rocker Arms 1.52 Ratio, Ported Throttlebody, Ported Intake Manifold, 3.73s and Auburn LSD, Yellow Underbody Neons, Milled Heads, Pacesetter Headers, TransGo Shift Kit, 1 Piece DS, Accel Coils, Rk Sport Air Temperature Module<p>Soon Mods:<br />Nos 5175, Rims, Stage 2 Jet Chip, Jet Underdrive Pullys, Strut Tower Brace, Subframe Connectors, Speed Calibrator, Lowering SpringsTags: None
When I had the gutted cat in, the tone was a little deeper, but not much. The gutted cat acts as a resonation chamber, changing the tone of the exhaust. As far as performance, I couldn't tell any difference. I have the straight pipe on now because the ground clearance is a little better with it.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Moving to General Tech.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
My gutted cat sounded all ricey and nasty, but once I got my straight pipe on (2.5 inch spread to fit 2.5 inside(Y-pipe), and shrunk to fit 2.25 inside(I-pipe) and 22.5 to 23 inches long) It sounded tons better. No difference in performance. But it sounded way better. I had to saw the end of the I pipe off, where it meets the cat, and I tried clamping it a couple times. Just ended up ruining a couple straight pipes. Just weld it up, trust me. I left a clamp on the Y-pipe so I can drop it off at the track. It's way too loud for the city when it's detached, but it helps about .2 at the track. [img]graemlins/burnout.gif[/img]Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
true that, screw gutten go straitRK sport headers<br />slp cai<br />custom transmission work/shifts at redline and quick as hell<br />b&m shifter plus<br />no back seat<br />no cat or muffler to z28 dual exhaust<br />160 degree temp<br />highflow rubber elbow/removed throttle body screen<br />200rwhp<br />eibach lowering springs<br />silver RS decals<br />brother\'s \'98 formula rims<br />400 watt jenson with rocksferd HE 12<br />nitrous or gears for the future
