Welded RK Sport 3.8's - FirebirdV6.com/CamaroV6.com Message Board
  • Welded RK Sport 3.8's
    Ok, after reading at least 100 posts on these headers, including about 90 posts on them leaking. I'm thinking about having the headers and the y pipe welded together. Is this a wise idea? Will it prevent leaking? Cause any problems? I was going to get new gaskets and flanges but they didnt have them in my size.
    1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather Interior
    i would get them welded on to save you the trouble of having to do it later on. also don't use the gaskets that come w/ the headers,try and get the original equipment(oem) style gaskets.i had mine welded at the y-pipe. i left the $hitty rk sport gaskets on where the header meets the head and they started leaking on the driver side so i replaced them w/ oem style gaskets(which are completely metal)nd i didn't have to cut the welds to get extra clearance. once the header was unbolted they slipped right in. hopes this helps you out.
    96 wht. firebird 5sd. rk sport headers,3in.catco, spintech catback,CAI,FRA,3.42/lsd 180*t-stat, centerforce dual friction clutch, ls1 driveshaft, polyurethane trans. mount.<br />01 blk. z28 m6, borla exht, lid, k<br />+n, sfc., chrome 18in. y2k c5 wheels.
      It certainly did, thank you. I've tried to find other gaskets/flanges that are stronger and have a three bolt pattern but all they have are ones for small block V8's :mad: Can I keep the flanges on the headers and y pipe if i weld them or should I get thicker ones?
        Any competent exhaust/welding shop should be able to put on new flanges for you, and would have standard 3-bolt HEADER gaskets for them. I don't know why RKSport decided to use a design that would warp more easily and that didn't have a proper gasket made for it.
        And NO, I would NOT weld the headers to the y-pipe. Although this would prevent leaking, it would also make it so you had to cut the headers off from the Y-pipe if you ever needed to take them off for anything. (Such as engine work... Whether it's to port and polish the heads or to replace a blown head gasket.)
        -James<br /><br />\'96 3.8L A4 Camaro (SOLD)
          I second what RacerJ said, don't have the y-pipe welded to the headers. Just get 3/8 inch 3 bolt flanges welded on. It's that simple.
          1 of a kind<p>Red 97 Camaro<p>Modifications: <br />SLP CAI, RK Sport Headers, Car Sound High Flow Cat, 3\" piping<br />3\" Steel driveshaft, SFC\'s, Panhard Rod, MAC Torque Arm<br />Manual Fan Switch<p>Best E/T:<p>60\' 2.152<br />330 6.271<br />1/8th 9.704<br />MPH 71.93
            I'm going to have to go with rob231's idea of welding the headers to the y-pipe only because I can't find a 3 bolt pattern for the flanges/gaskets (2.25") that match. The only partial luck I had was discount performance having 2.5". Does anyone know where i can score a pair?
              welding them on won't give any problems doing engine work. all you do is unbolt them and they slide right off, away from the engine. you could easily take off the valve covers and heads. now if you were to take out the trans. then you would have to cut, but do not be scared it can all be easily welded back. it is a small price to pay for no leaks.
                LISTEN a lot of people have given you wrong information. THE FLANGE size has nothing to do with warping.... it is the 2 bolt pattern that causes a problem.. the 3 bolt flanges are the same thickness as the problem 2 bolt flanges.
                  My Hptuners stop working
                  Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                  11 hours ago
                • Money pit
                  Zzp cams
                  by Money pit
                  Has anyone used zzp gt1 cam if so is it worth the money and time
                  2 days ago
                • thatpewterfirebird
                  2001 3800 s2 firebird
                  by thatpewterfirebird
                  3 days ago
                • Turbo 3800 camaro
                  Where are the videos?
                  by Turbo 3800 camaro
                  6 days ago
                  New Chevele
                  Just saw it on Facebook, looks awesome. The front and rear nice looking....
