Alright guys Im going to the dyno tomorrow, Tuesday Feb 19, 2002, around lunchtime. $50 for 3 runs, and here's what I plan on doing with the 3 runs.
Run 1 - Normal
Run 2 - Normal
Run 3 - Remove MAF screen
Hopefully I'll see a significant change in hp/tq numbers by removing the screen on the last run - I'm guessing it will be lower because of what I saw at the track.
My questions are as follows:
Thanks guys - I would like responses to be quick if possible, I'll be leaving tomorrow - wish me luck...
Run 1 - Normal
Run 2 - Normal
- Are there any preperations I need to make to the car before going?
- Is there anything I need to know about while being ON the dyno itself?
- Is it worth going?
- I heard about bad spark responses throwing off torque curves for the dyno, is this common? Can I do anything to prevent this? I run stock wires.
- Does anyone have any idea what kind of numbers I should expect to pull with a 9.7second 1/8 mile time?
