How does it sound compared to the stock one?
Sounds of High flow cat
most likely (depending on which cat back you have) mine only rasps for a few seconds around 3k then its just a higher note due to being a v6 and also if im at high rpms and just let off the gas (without pressing the clutch). i have loudmouth btw\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
correct unless you want some sort of strange bottleneck in there\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
