hate o2 sen - FirebirdV6.com/CamaroV6.com Message Board
hate o2 sen
  • hate o2 sen
    this sux how in the world can i take out the o2 on the passeger side any ideas please!!!!!!!!!!
    2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
    Get the adapter so you can turn it with a socket wrench, then just unscrew it.
    Matt
    1998 Mystic Teal Camaro M5
      what adapter? and where can i get one?
        You can get it from any auto parts store. It slips over the sensor and lets you use a socket wrench to turn it.
        Matt
          whats it called so can go right now and get it
            you can use a metal pipe or pcv. i call it a braker bar. get a wrench that fits the bloody thing and crank it with the bar. its all about leverage.
              do you not have an open ended wrench?
              2000 3.8 A4 Pewter Camaro
                yeah but i tryed but i can fit the dawm wrench in there i was think of geting a o2 sim to take care of it
                  Definetly don't want to do that. Only use an O2 Sim on that after-cat sensor.
                  Matt
                    well i only have 2 one on driver side header and the other on is the pain in the but on the other header passeger side which i think is the one the reads the cat
                      You have 3. There is one after the catalytic converter. It is further aft of the manifolds.
                      How can the one on the passenger side manifold read the cat if it's way upstream of the cat?
                      Matt
                        i dont see the other one by the cat where is it i look all over when i took my car it thruogh this code p0141 so i though i could use o2 sim for that on since that one link that i put said if that code was showing use a o2 sim
                          P0141 is for the after-cat sensor. It is downstream of the manifolds. Look for the catalytic converter, it should be right after that.
                          Matt
                            ok ill check for it but if it cant fined it then what do i do?
                              Keep looking. It's gotta be there. If it's not there, then it somehow fell out and you'd know it from the huge exhaust leak. If it somehow did fall out, you could still trace the wire that would go to it.
                              Matt
