this sux how in the world can i take out the o2 on the passeger side any ideas please!!!!!!!!!!
hate o2 sen
hate o2 sen
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
what adapter? and where can i get one?2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
You can get it from any auto parts store. It slips over the sensor and lets you use a socket wrench to turn it.Matt
1998 Mystic Teal Camaro M5
whats it called so can go right now and get it2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
you can use a metal pipe or pcv. i call it a braker bar. get a wrench that fits the bloody thing and crank it with the bar. its all about leverage.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
yeah but i tryed but i can fit the dawm wrench in there i was think of geting a o2 sim to take care of it2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-El:
yeah but i tryed but i can fit the dawm wrench in there i was think of geting a o2 sim to take care of itMatt
well i only have 2 one on driver side header and the other on is the pain in the but on the other header passeger side which i think is the one the reads the cat2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
How can the one on the passenger side manifold read the cat if it's way upstream of the cat?Matt
i dont see the other one by the cat where is it i look all over when i took my car it thruogh this code p0141 so i though i could use o2 sim for that on since that one link that i put said if that code was showing use a o2 sim2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
P0141 is for the after-cat sensor. It is downstream of the manifolds. Look for the catalytic converter, it should be right after that.Matt
ok ill check for it but if it cant fined it then what do i do?2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
ok ill check for it but if it cant fined it then what do i do?Matt
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
