check this out u think this will work? http://www.zzperformance.com/zzp/pro..._simulator.htm
what u guys think about this
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
If you're still talking about your B2S1 O2, then no it won't work. If you're talking about the after-cat sensor, then yes it'll work.Matt
1998 Mystic Teal Camaro M5
i only have 2 o2 one on the driver side and the other is the passenger side. the passeger side is the pain in butt one with i think reads the cat2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-El:
i only have 2 o2 one on the driver side and the other is the passenger side. the passeger side is the pain in butt one with i think reads the catMatt
what i was try to say on this one is this better then capper or do they all work the same2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
i met casper2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
im still kinda confused if your wanting to put a sim in place of your manifold sensors or the after cat.......anyways, my casper was cheap and has worked great for me
