SES Code - FirebirdV6.com/CamaroV6.com Message Board
SES Code
  • SES Code
    I have keep throwing P1406 EGR Position switch code. I have no clue what this means. Do I need to look into a new EGR system, or just the switch? And what the hell does it look like so I can see if I bumped a wire loose when I moved my IAT? I know there are some EGR wires bundled with the IAT wires.
    Probably going to need a new EGR valve.
    DTC P1406 EGR Valve Pintle Position Circuit
    It means that the valve is stuck or not operating correctly. The EGR valve looks like a cylinder and is located near the driver-side exhaust manifold. You'll see a pipe coming from exhaust manifold to the base of the vavle, then another pipe from the base to the upper intake manifold.
    If I remember correctly, it costs about $99 from Autozone.
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      What kind of advantages and problems will I have if I take the EGR off completely? Obviously a constand SES light, but what else?
        This has been discussed in depth before, but I'll go over some basic pros and cons.
        Cons:
        constant SES light (the PCM will know its blocked off)
        increased emissions [img]tongue.gif[/img]
        Pros:
        hmmm, none really
        no one's ever mentioned any noticable gain
