Pacesetter Q... - FirebirdV6.com/CamaroV6.com Message Board
Pacesetter Q...
  • Pacesetter Q...
    I have everything installed but did you guys have a problem with the middle spark plug on the passenger side? I couldn't get the 4 cylinder plug cable to attach because of pipe construction. Did you all have problems with this and where can I get L plugs. Also the valve on driver side front doesn't go in. I think the workmanship in the headers isn't quality.
    Factory:Camaro 5 speed, Color Pewter, w/ t-tops and Y87 package. <br />Engine: K&N filter w/ Whisper Lid, FRA, Borla adjustable cat-back exhaust. Hurst w/ Short Stick<br />Interior:Oil temp. and Air/Fuel ratio gauges, System.<br />Exterior: Black outs front and back, 18 in. Lenso rims w/ Kumho Supra 275/35ZR18 tires, also limo tint on sides and back.<br />173.2rwhp-----200.5tq
    You need L shaped plug ends.
    I am assuming that by "valve" you mean EGR tube, it will go in, you may need to do a little grinding or something, to get it to fit, then just make a gasket from some ULTRA COPPER RTV.
    1997 Dodge Viper GTS
      Jeeez, pacesetters seem like more trouble than theyre worth from all this stuff I keep hearing...
        Trick on installing back your EGR connection without a LEAK!
        Unbolt the EGR housing from the block and the thermostat housing off the block. Bolt the EGR hose to the EGR fitting first(header), then bolt the EGR housing back to the block and then put the thermostat housing back on the block also. Make sure everything is tight back to OE specs. Taa-Daa! No leaks, THE END. ;)
        <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
          your right. if you want to break your tube like i did then dont try it his way ;)
          2000 3.8 A4 Pewter Camaro
            For the passenger side, use the 5/8" spark plug socket. BUT don't use the socket wrench, use an open end wrench to turn it. This is how I have to do mine to avoid cracking it. Works great!
            And what do you mean by they are not quality? Poor welds? Only half-way coated?
              All try the other EGR method. By quality I mean, the 4 cylinder spark plug shouldn't have to be that hard to get at. But everything is on and EGR is in but did anyone find it hard to put a spark plug on the passenger middle cylinder. Mine is hitting the header and melting it where are good plugs that
                All try the other EGR method. By quality I mean, the 4 cylinder spark plug shouldn't have to be that hard to get at. But everything is on and EGR is in but did anyone find it hard to put a spark plug on the passenger middle cylinder. Mine is hitting the header and melting it where are good plugs that are short for the spark plug end?
                  Sorry about the first one above.
                    just delete it ;)
