I went to a local shop to see how much it would cost to have the loudmouth put in. The guy said that i diddnt need a new cat because the stock one is one of the best ones you can get????? Will getting a new cat make my exhaust louder or not?
cat with loudmouth
cat with loudmouth
1994 White A4 Z/28<br />Mac Headers, Flowmaster, <br />1LE Intake Boot, TB Bypass,<br />TransGo Shift Kit<p>1995 3.4L A4 Camaro<br />K&N Intake, SLP Loudmouth Exhaust,<br />3.73 gears, B&M Shift Plus<br />30th Anniversary Racing Stripes<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=241488\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=241488</a> SOLDTags: None
You'll hear this alot from exhaust guys that don't want to mess with the cat. There's a lot of EPA regulations and BS that go along with a catalytic converter, so a lot of shops try to avoid working on them. At least, that's what I've found. Try another shop. A high flow cat is going to flow better than the stock cat.1997 Y87 Camaro with a motor and some stuff.
black stripes: The stock cat SUCKS. There. I said it. The guy at shop was lying.
Not only will a high-flow cat improve hp/torque, but it will also deepen the exaust sound.
Catco is a good brand; Random Technologies is excellent too. Shop around for a good price on one, and find a shop that'll install one (or get a couple of friends and do it yourself).
BTW, try and find a cat that matches the Loudmouths' size (3 inches). Guarantee you'll have one of the loudest cars here [img]smile.gif[/img]16 years old with no car and big dreams...
I wouldn't do it.
Scott had a high flow cat on his loudmouth setup and he said it sounded repulsive.
I kept the stock cat and it sounds great... not to mention there is very little back pressure already, hurting low end. Going to a 3" cat would just amplify that.
Unless you are running some kind of poweradder I would just save the cash.
SamAIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
