Here is one more for you guys, I also plan on installing a high flow catalytic converter from either Random Technology, or Catco. Which is better, as far as performance gain? Also which part number should I be looking for if I plan on installing in my 3.8 V6?? I know about the 3inch in and out is 2.25, but I plan on changing that pipe to a 3inch bent vortex pipe. Any suggestions??
High Flow Catalytic Converter Question..
You going to find the one high flow cat is probably just as good as another (btw, this is probably going to get moved to exhaust). Just make sure you get the right inlet/outlet size that you want. The gains/loss between the two will be nominal at best. Also, unless your going to do a power adder mod, the 3" is overkill and would better/cheaper to go with a 2.5" or 2.75.
my 2 centsNot a problem, just a challenge...
