if you unplug an o2 sensor from the cat, you'll set an ses light, correct? well, if you plug the o2 sensor back in, will the light go off? will the code be "o2 sensor unplugged." because i'm trying to figure out a way to get my cat replaced under GM's warranty, and i would think this would work. suggestions?
FIGURED IT OUT!!!
Why?
If it's a stock one, just wait for it to go bad and go get yourself a high flow. If you have some strange reason for actually wanting a new factory cat, just pop the band off and break some internals... Use something blunt so it doesn't make scratch marks. Then you can have a brand new cat and the guilt of ripping someone off while your soul burns in Hell for eternity, sinner. [img]tongue.gif[/img]\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
ok i c...well the darn cat sux and i think it's clogged. i want another one :( but don't want to pay the $50--i mean, if GM will give you one for free, then why not get it? it flows pretty good from what i hear...2000 NBM M6 Camaro Z28<br />323/335
<blockquote>quote:</font><hr>Originally posted by Fear_Factor:
Just go the cheap route and gut your cat. That is what I did ;) <hr></blockquote>
Then you'll have a 50 percent chance of throwing a code and have to buy an o2 sim anyway.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
