setup - FirebirdV6.com/CamaroV6.com Message Board
setup
  • setup
    I am planning on going with a 3" catco and a 3" american-thunder (flow master)I was wondering if I should go with the ls1 or the lt1 kit, mainly which one requires less fabrication? thnx
    A good friend will come bail you out of jail. But a true friend will be sitting next to you saying \"That was <br />F%#@ing awesome!\"
    help? [img]graemlins/crybaby.gif[/img]
      <blockquote>quote:</font><hr>Originally posted by bluev6:
      I am planning on going with a 3" catco and a 3" american-thunder (flow master)I was wondering if I should go with the ls1 or the lt1 kit, mainly which one requires less fabrication? thnx<hr></blockquote>
      What year is your car? If it's pre 1998 use the LT-1 kit if 1998 or newer use the LS-1 kit
        get the lt1 kit.
        \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
          The LT1 kit includes the S-Pipe to connect directly to your Cat.
          <b>2000 NBM Pontiac Firebird</b><br />3800GT Performance Package<br /><br />Intake, Magnaflow Cat, Flowmaster Cat-Back
            use the lt1 reguardless of your year, the lt1 kit comes with an s-pipe most likely since the first lt1's had a single cat setup like our 6's
            <a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
              If you get an LT1 kit, make sure its for the 93-95 LT1, because those were the single cat (like ours) and the 96-97 was the dual cat. So go with the 93-95 LT1.
              2001 Camaro A4<br />Maroon Metallic <br />Y87,Monsoon 500w,TTops<br />Appearance: Silver ZR1s w/ 275\'s<br />Intake: !Air Silencer, FRA Mod, k&n<br />Exhaust: 3\'\' Cat, 3\'\' B&B TriFlo<br />Misc: SLP Fan Switch, 1LE Boxed LCAs <br /> <a href=\"http://www.cardomain.com/id/mshapiro\" target=\"_blank\">http://www.cardomain.com/id/mshapiro</a>
                Thanx alot!!! I am planning on ordering it soon :D
