I pretty sure I have a clogged cat. Replaced ICM, Plugs, Wires, and Coils. Still having bad problems. I can't rev above 3000 rpm when driving or above 3500 in netural. There is a odd hissing and rattling sound coming from the exhaust. Could this be the problem? What is the easiest way to remove the cat?
Thanks
Got a sawzall? If not, rent one from home depot and have fun!
Or, you can buy a cat from summitt racing, or get a carsound cat (I recommend a carsound cat), and bring it to a muffler shop. They normally charge $40-$80 to cut the old one out and weld the new one in.
Should unbolt from the collector and intermediate pipe flanges, although depending on how old the car if you can get it off without twisting off a bolt.
I had the same problem.. it was because I crushed my cat on a rock. Grabbed that thing by its tail and SMACK! [img]graemlins/omg.gif[/img] Dead cat.
00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
<blockquote>quote:</font><hr>Originally posted by FunkZ: Should unbolt from the collector and intermediate pipe flanges, although depending on how old the car if you can get it off without twisting off a bolt.<hr></blockquote>
What. I wish getting the cat off was that easy. Depending on your year it could be welded on both ends so you would have to cut it out and weld a new one in.
can you use like JB weld or anything? i don't have access to anything to just weld it regular... but if like JB or something like that would work that would kick @$$
<blockquote>quote:</font><hr>Originally posted by speedy-v6-camaro:
What. I wish getting the cat off was that easy. Depending on your year it could be welded on both ends so you would have to cut it out and weld a new one in.<hr></blockquote>
Mine was bolted via flange front and rear. I assume at least other 3.4 would be the same. So the 3.8 cat is welded?
<blockquote>quote:</font><hr>Mine was bolted via flange front and rear. I assume at least other 3.4 would be the same. So the 3.8 cat is welded?
<hr></blockquote>
Mine is held in place by a bracket and welded on both ends and I have a 99 3.8.
Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
